Use the following general tasks to isolate connectivity problems:
Check physical connectivity. Verify if an alarm for link or port down exists.
Check the link state by viewing the show interfaces {gigabitEthernet|loopback|vlan} command output.
Use tools like ping or trace to verify if the connectivity issue is localized to an individual port or VLAN.
Try to localize the affected range of ports and slot.
If you contact technical support staff to help troubleshoot connectivity problems, always provide source and destination IP pairs to facilitate in troubleshooting. Be sure to provide both working and non-working pairs for comparison.
Switch:1#show interfaces vlan
Vlan Basic
VLAN MSTP
ID NAME TYPE INST_ID PROTOCOLID SUBNETADDR SUBNETMASK VRFID
1 Default byPort 0 none N/A N/A 0
2 VLAN-2 byPort 0 none N/A N/A 0
50 mcast_smlt_3 byPort 1 none N/A N/A 0
60 mcast_smlt_4 byPort 1 none N/A N/A 0
All 4 out of 4 Total Num of Vlans displayed
============================================================================== Vlan Port
VLAN PORT ACTIVE STATIC NOT_ALLOW
ID MEMBER MEMBER MEMBER MEMBER
1 1/5-1/8,1/10-1/48, 1/5-1/8,1/10-1/48,
2/2-2/4 2/2-2/4
2
50 1/1,2/1/3-2/1/4 1/1,2/1/3-2/1/4
60 1/3-1/4 1/3-1/4
All 4 out of 4 Total Num of Port Entries displayed
VLAN VRF Association
VLAN VRF
ID NAME
1 GlobalRouter
2 GlobalRouter
50 GlobalRouter
60 GlobalRouter
4086 GlobalRouter
4087 GlobalRouter
--More-- (q = quit)
